Sony VGN-NW24S How do I update the BIOS.
Hi all,
I have searched high and low both here and on the wider internet before asking this, but can any of you please direct me to where I can download the latest BIOS for my Vaio please?
It is a VGN-NW24S running Windows 7 64bit SP1
The current BIOS is showing as American Megatrends Inc 2009, so I would imagine that there have been some updates since then, although I am struggling to find it! Vaio update shows no new updates either.
Thanks for your time and if you need to know anything else then please ask.
1 REPLY 1
rich912
Contributor
Hi Huckmeister,
There is no BIOS update released for this model. Updates are only normally released by Sony if there is a problem.
Is there any particular reason you are seeking an updated BIOS?
Rich
Go n-éirí an bóthar leat
