Texas Instruments PCIxx12 Integrated FlashMedia Controller
profile.country.de_DE.title
sibanwo
Pls can somebody tell me where to get the new version (Texas Instruments PCIxx12 Integrated FlashMedia Controller)
4 REPLIES 4
Blencogo
Hi Simon.
Is this the one you want?
sibanwo
Hi Simon.
Thanxx Blencogo , u are allways helpfull i´ll try it and let u know if its works.
THANNXXX AGAIN MAN!!!!
sibanwo
Hi Simon.
Hi Blencogo, can u pls tell how to open the file?
Blencogo
Hi Simon,
Right-click on the .zip file and choose "Extract All". Choose to extract the files to a folder where you can find them later - say C:\FlashMedia
You will have to install the driver manually from Device Manager. Right Click on your MS device in 'Disc Drives' and choose 'Update Driver'. In the Wizard, choose all the options to manually choose the driver to install yourself and point the wizard at C:\FlashMedia\ti21Sony.inf
If no flashmedia controller is installed, you will find it in Device Manager as 'Mass Storage Device'.
:wink:
