VGX-XL301
jaworszczak
VGX-XL301
hello.I Have problem to upgrade my Win dvd program to play the Blue-ray disc.Any time I try to upgrade ther is a Memo:THIS UPGRADE PATCH CAN'T APPLY TO YOUR VERSION OF WIN DVD.SEAT UP WILL NOW ABORT...
I been told to upgrate version 8.0.06 114 followed by 8.0.8 406 .Thank you.
1 REPLY 1
Thalamus.
Champion
Hi
welcome to Club VAIO.. :slight_smile:
Have you installed the InterVideo WinDVD 8.0.06.114 followed by InterVideo WinDVD 8.0.8.406.?
If not use the following link to download the updates: XL301 InterVideo WinDVD
The follow the instructions to install InterVideo WinDVD Update Version 8.0.06.114
How do I update my software?
1. Exit all running programs
2. Download this update and save it to your hard drive (please note this download location).
3. When the download is completed, locate the downloaded file in the location you specified.
4. Double-click ITAOTH-01453101-UN.exe to run it.
5. Wait while the wizard updates your software.
6. Click OK when the update is completed.
7. Restart the computer to complete the installation.
Then InterVideo WinDVD Update Version 8.0.8.406
4. Double-click the downloaded file to run it.
