wireless internet connection help
pabblo
Посетитель
Hi i have an K215b ,i have a main computer connected to broadband via a ethernet cable connected to a usb cable plugged into a usb 2 port, what do i need to connect my notebook up to this connection wirelessly? suggestions on which pieces of kit i need would be helpfull as i am completely new to networks and wireless networks thanks....
2 ОТВЕТ 2
NigelR
Посетитель
Go to ebuyer.co.uk and buy a Netgear DG834G or a Belkin F5D7630-4A both wireless both great.
TygerTyger
Посетитель
I'll add a vote for the Belkin....free technical support and a lifetime guarantee (provided you buy it from one of their approved stockists, which is quite a long list actually) What more can you ask for? It works great, and one of their approved stockists was selling it for like £50, which is a bargain.
If you're after speed, USRobotics are selling modems that work at 100mbs, upgradable to 125Mbs for free via a download. Be warned, the manual is non-existant and it put me through hell. Vote Belkin.
