NW-A306 Verify PIN options?
oviteodor
Исследователь
Hi all,
I've purchased a second hand NW-A306 from eBay and is locked.
What are my options now? Will Sony help me unlock it?
Android 12, and firmware 2.00.02/19
3 ОТВЕТ 3
https://helpguide.sony.net/dmp/1301/v1/en/contents/TP1000733584.html
If you forget the method that you have set for unlocking the screen (PIN, password, pattern, etc.), you will not be able to unlock the screen yourself.
- Repair requires a fee.
- All data will be erased because the repair requires reformatting.
Anonymous
Неприменимо
Hey, this will require to be done at the Sony authorized service centre
You can locate the nearest one to you here: https://locator.sony/en_GB/servicecenters (don't forget to check your product category!)
oviteodor
Исследователь
I tried to contact multiple service stores around London, no one answered to the phone.
As this walkman was purchased from eBay, I deduced to return it for a full refund.
Please close this thread.
