Sonic Stage 3.1
profile.country.en_GB.title
peterbb
Sonic Stage 3.1
Any answers for the following: In Sonic Stage 3.1, My Library has tracks that do not show in the' View' all tracks listings.
2 REPLIES 2
profile.country.GR.title
gogos7
Maybe you have to import them manually? File -> Import -> Scan Folder -> Settings (in pop-up window) -> and then select one (or more) specific folder.
And why do you use an old version? Mine is 4.3 and maybe there is a newer available.
peterbb
Thanks for that gogos7. This version is on my desktop which has the majority of my collection on it. The laptop came with Vista and I have the 4.3version installed but as you may be aware, they are not compatible for exchanging files etc. I was going through tracks and noticed that one tracks from an album hadn't registered in the View Tracks mode. Will try again.
