boot loop.. help!
profile.country.en_GB.title
mrtegg
boot loop.. help!
my tablet s is stuck in a boot loop is there any way i can fix this without a factory reset? Please help!..
12 REPLIES 12
amillionbytes
hey ,an I had this failt a while ago, caised by a corrupt media database: swhirl swhirl swhirl lock screen blip swhirl swhirl swhirl lock screen blip swhirl swhirl swhirl...
only solution was to reset the tablet to Factory Defaults.  there's apost around fhere with thedetails.  I just the blond girls in the Netherlands on Sony Support and they were ace :slight_smile:
joerics13
I have the same problem, but when I use the power and vol + menu nothing happens.
If I hold long enough it just turns off again. If I let go of the power on/off button it gets stuck with the wavy blue lines.
jumpsuit
Have you tried posting in the official Xperia forum Here?
You may be able to find some more information or help there :slight_smile:
