Hello, having just purchased a vaio TAP 11 tablet, model no.svt1121b2e, I'm at a loss as to how access the GPS if indeed an internal GPS is installed. Any advice will be appreciated.
kind regards
Q
Everywhere I look, GPS is not listed in the specifications.
Perhaps you should try phoning the Sales Line for confirmation.
Not sure what model you have, but if you do have a model with 4G then i'm certain you would have GPS.
