How do I open the headset jack cover ?
Koko
I am really struggling to open the headset jack cover on the Xperia z Tablet... where do I put my fingernail and which direction does it open ? Thanks !!!
Uliwooly
Look closely at the cover/flap there should be a small gap
4 REPLIES 4
Uliwooly
Koko
On the side towards the power button, or at the top (towards the screen), the bottom or the left ? Thanks again
Koko
Found it on top towards the screen.
Thalamus.
Champion
Hi Koko,
welcome to the Sony Xperia Support forum..
If look at the headphone cover you should see a small gap using your finger nail you should be able to flip the cover out..
See image below, although not the headphone port, it should give you an idea of what the small gap should look like..
Edit: seems I was to slow in typing my reply..:smileyexclaim:
