Internet conection with sgpt 111
profile.country.el_GR.title
sbexcp61
Hello every body
i have sony tablet sgpt111us/s wifi version and i need to connect it to mobile internet through a usb stick. How can i do it????
In advance the same tablet does not support greek characters which actually i need as well.  Other editions of the same tablet do so. I am sure that some how i can install greek language i dont know how to do it though. Any idea???
Message was edited by: sbexcp61
Tags (1)
2 REPLIES 2
profile.country.en_GB.title
mpattenden
Unfortunately if you are talking about attaching a usb dongle to your tablet s this isn't supported. You need to use wifi or change/upgrade your dongle to something like the 3 MyFi.
Sorry it's not better news but hope it helps.
Regards
Padster
sbexcp61
Thanks for your help Padster
