Maximum memory card capacity
Girts
Is maximum memory card capacity in Tablet Z LTE SGP321 really only 32 Gb? Also, does high speed rating (class 10) really matters, let's say, as in photo cameras?
saanmedio
The latest SW update allows you to go to 64gbs
6 REPLIES 6
Uliwooly
Anything above Class 6 will be ok ,but check this out before you buy anything
http://pocketnow.com/2012/05/28/android-guy-weekly-everything-you-need-to-know-about-sd-cards
Girts
OK, it's more or less clear now about speed factor in tablets, as there is more data to read that to write. But what about maximum card capacity in model SGP321?
Uliwooly
64GB
Girts
How could it be 64 Gb if the White Paper says 32 Gb? I was asking only because I couldn't believe it's so small to today's standards. Also why can Wifi version hold up to 64 Gb, but "flagship" LTE version only 32 Gb? Please advise me before I make any purchase.
saanmedio
MrEdandzeus
Hi
Has there been a software update to allow 128gb sd cards to be used? If not is there likely to be one soon?
Thank you
