Noise cancelling headphones
Sparkypaul
Hi all. New to the forums.
I received my Z4 at Christmas and loving it. Today my daughter bought me a pair of noise cancelling headphones (Sony Mdr-zx110na). The headphones sound great but I am unable to switch the noise cancelling option on in the settings. It is permanently greyed out. Am I doing something wrong?
Thanks
Lord_viridis
That model controls it's own noise cancellation.
The nc features are all contained within the headset itself including the on off setting.
Refer to the manual to learn the correct opeation for nc power.
4 REPLIES 4
Phy
Legend
Legend
Try to clear the SmartConnect app data.
1. Tap the Application screen icon.
2. Find and tap Settings > Apps.
3. Swipe to the All tab.
4. Find and tap on the SmartConnect app.
5. Tap Force stop > Clear data.
6. Restart the phone
Lord_viridis
Lord_viridis
Bottom panel of the left earcup contains your power options..
AINC is the noise cancellation
Sparkypaul
Thanks for the speedy responses. Now I know this model controls it's own NC I'm a happy chappy. Thought I was doing something wrong.
Thanks
