Hi All,
I'd like to be able to open 2 PDFs on the same screen - reading one using any PDF reader and have a secondary one side-by-side or floating - however.
Is there a way to do so in my Xperia? Or is anyone aware of PDF widget?
Thanks!
There doesn't seem to be a small widget for that, however you could download maybe a split screen app or dual screen app.
Thanks, unfirtunately I thought that is the case...
Can you recommend any such dual screen / floating apps? Especially those fully compatible with Xperia tablet?
BTW, are there any news when (hopefully when and not if) Sony will update Xperia Z3 with Android 6? AFAIK v6 has this dual screen feature...
I don't have this tablet anymore so I can't test the apps myself https://play.google.com/store/apps/details?id=screen.tasking.multi.window
