Problem with office 365 web app
Grumpals
HI
I can't seem to get the office web app to work right on my Sony Tablet Z, when I log into my skydive and try to start a new doc or execl sheet it just takes me to a blank page, I've tried Chrome, Firebox and the Dolphin browsers and all do the same thing.
On my desktop no issues start a new file and all the office menus show up. (I have a office 365 subscription. But have not yet installed office on computer)
Has anyone found a way to get the Microsoft web apps to work on the sony  tablet?
Thanks
Prasadm1
Have you tried turning the "Desktop" mode on in settings of the browser and check if it is working ? Maybe the application doesn't support mobile mode..
4 REPLIES 4
Prasadm1
RAW_777
Creating new documents within Chrome browser while on SkyDrive works fine here. You may not have purchased the OfficeSuite Pro app however in which case the included OfficeSuite app is only a viewer I believe?
Grumpals
Thanks for the replys
I do have a full supscription to office.
I did find it does work with Puffin browser and not with anyother browser, i'm thinking it might have something to do with flash but i don't know for now i'll just use Puffin
Thanks
Grumpals
Hey Thanks Prasadm
did turn it on but must have turned off when i tried it, but it works now
Again thanks
