Streaming from xperia Z to tablet Z
ArunMenon
Is there anyway to stream music from Xperia Z to tablet Z without using any third party application, or transfering the file.
Johan
Master
Yes you should be able to do this if both devices are connected to the same Wi-Fi network and you enable Media server on your Xperia Z.
Settings > Xperia-connections.
When you have enabled media server in your Xperia Z your should be able to stream music using Walkman in your Xperia tablet Z.
1 REPLY 1
Johan
Master
