Does anyone know if the digitizer pen from the vaio duo11 will work with the xperia tablet Z,The chat line operator tells me that vaio and experia are not the same company i.e.Sony ???? and was no help at all. If not this, can anybody recomend an active stylus that will work with the xperia tablet Z
Sorry to hear the person you chatted to doesn't know our organisation correctly :S
regardless, I don't think the pen will work fully.
The pen has been designed exclusively to work with the VAIO DUO and its screen. The screen on the Tablet Z is different. Although I am sure some basic actions will work, I would not be so 100% sure for more accurate work.
Kindest regards,
Nico
Kindest regards,
Nico
