Tap to zoom not working
profile.country.en_GB.title
dweaver1
My browser has stopped 'tap to zoom' - is there a setting for this, or is it another 4.3 issue?
profile.country.RO.title
_alexdon_
How about if you remove the updates for chrome?And did you try another browser?
alexdon
7 REPLIES 7
_alexdon_
Try to force stop and clear data for the browser.
alexdon
Uliwooly
Which browser are you using?
dweaver1
alexdon - thankyou for this.
Just done this, but unfortunately no change...
dweaver1
uliwooly - the chrome browser.
_alexdon_
alexdon
dweaver1
alexdon - thankyou, it worked....
_alexdon_
You are welcome.
alexdon
