Xperia Tablet Z MicroSD specfications
I have checked the user guide and various web sites but I haven't been able to get an answer as to what the MicroSD specifications are for this device (SGP321).
I'd like to know what the maximum capacity of MicroSD card is for this device, and if it supports SDXC cards. I'd like to get a 64Gb SD card. I'm currently using a 32Gb SDHC card.
The Android version on my Tablet Z is 4.1.2. I don't know if this version supports the exFAT formatting type needed for memory cards larger than 32Gb.
Thalamus.
Champion
Hi Dillspooch,
Welcome to the Sony User Community Forum..
According to the Xperia Tablet Z specs page it supports the following:-
Interfaces
Headset jack Yes Memory Card Slot Micro SD memory card x1 Supported SD memory card microSD, microSDHC, microSDXC2 USB type microUSB-AB USB version 2.0 High Speed (480Mbps) HDMI Yes via MHL support
- See more at: http://www.sony.co.uk/product/xperia-tablet-z/tab/editorialarticle1#sthash.qYqOjbHG.dpuf
As to the maximum SD card it states on the Sony Mibile site:-
Memory
RAM: 2GB
Flash memory: Up to 16 GB
Expansion slot: microSD™ card, up to 64 GB [2]
See more at :-http://www.sonymobile.com/global-en/products/tablets/xperia-tablet-z/specifications/
Hope this helps, I'm on my mobile phone, but I would have thought the SD card info would be in the user guide if you want to double check the info I have posted is correct..
3 REPLIES 3
Thalamus.
Champion
Hi Dillspooch,
Interfaces
Memory
RAM: 2GB
Thank you Thalamus.
Thalamus.
Champion
You're welcome Dillspooch..
