Lock screen with fingerprint bug
Bbbz
I have a problem with my xperia x lockscreen with fingerprint when unlocking the phone. After press button and scanning the fingerprint, the phone is not unlock in imediately. I have to input the back up pin again to unlock the phone. In addtion, I also see the icon on the bottom of the display if icon is a lock I have to enter a pin but if it is a finger print icon I can unlock the phone in imediately. Can anyone help me?
profile.country.RO.title
_alexdon_
3 REPLIES 3
_alexdon_
Bbbz
No, I am using stock home launcher. Thank you for giving me a solution. I can find the solution to solve the problem by disable "tap tap to sleep" feature of xperia home laucher.
_alexdon_
You can try to add xperia home as administrator, maybe it works and you can unlock using fingerprint only.
alexdon
