Xperia X charger specs: which one is compatible?
РЕШЕНО
Astra_moon
Посетитель
Hi! Slightly_smiling_Face
I own a Xperia X, but about a week ago, I lost my charger on the train. I have been searching on the internet for a while now, but I can't seem to find the specs of the original charger. (and in some countries you don't get all the booklets in the box with the phone)
I want to know the specs of it, since I was looking on the Sony website and I could find two different chargers compatible with Xperia X and I am not sure which one to pick.
I found the UCH10 and the UCH12. The biggest difference is that UCH10 has QQuickcharge2.0 and the UCH12 has QQuickcharge3.0. Which QQuickcharge version it is, doesn't matter that much, but the UCH12 doesn't show the wattage at any website I found.
So, the question is:
[What are the specs of the original charger of the Xperia X?]
or
[Which charger is best compatible?]
Page for UCH10
Page for UCH12
Теги (2)
1 УТВЕРЖДЕННОЕ РЕШЕНИЕ
Утвержденные решения
Christofer
Чемпион
Hi @Astra_moon, sorry to hear that you lost your charger. Slightly_frowning_Face
Based on the information available to me Xperia X comes with the UCH20 charger, a standard 5 V 1500 mA charger, though in some regions it was bundled with UCH10 as @Viridis said.
Both UCH10 and UCH12 are compatible with Xperia X. The device itself supports QuickCharge 2.0 but not 3.0 though so there would be no difference between using UCH10 or UCH12.
5 ОТВЕТ 5
Lord_viridis
The charger for X in most countries is UCH10. This is the charger that is included in most regions.
Christofer
Чемпион
Astra_moon
Посетитель
Thank you very much for your quick reply ^^ It will be much help to me!
ksuuk
Посетитель
Any charger will work. Usually I don't use the original one at all, no need, as I have already some noname charger.
Nuttie
Посетитель
I had uch20 out of the box, if you want quick charge get uch10 (QC2.0) becouse Xperia X doesnt support QC3.0 (uch12, which is twice expensive than uch10).
