Xperia X dual sim 's microphone issues
meekung
i 've bought my new xperia for 2 days when i called my friends.They told me that  sound is too low so they can't hear what i say completely. I think it may be noise suppression feature but i can't find the to enable/disable it.
Please told me how to make it works
Thanks
meekung
updated: I've contacted seller to test it. the new one has no issue.
everyone can hear my voice so seller replaced with new phone.
4 REPLIES 4
Uliwooly
@meekung
It can't be done, diable the noise suppression, could you test it in >>> safe mode ?
meekung
yes I've tested it in safe mode . Sound is ok everyone can hear my voice perfectly.when i restart to normal mode problem came back.
Uliwooly
@meekung'
then it's a third party app acting up
meekung
