Device get heat
senthilkumar1
Device get heat
After the new system update the device get heat even for normal usage
Tags (1)
Shailens
Actually after a update the device tends to get heat up, its normal.
But after 2-3 days it can be back to normal.
10 REPLIES 10
Duke17
What do you mean by normal?
senthilkumar1
Yes. It's warm even in normal usage of calling and browsing
Duke17
I think it's normal when you're using mobile data.
senthilkumar1
Yes
senthilkumar1
Device gets quickly warm at top of back side.
Shailens
senthilkumar1
OK, let's see
Solus
Sry Schailens but that Sounds stupid. I Do habe the Same Problem and waiting wont solve it. Its clearly an Software Problem. Phone Batterie is also Charging much faster After the last update. I also cant use the Phone while Charging cause it gets way to hot.
Solus
Its the top only. Front and backside is getting really hot. Also Battery drains faster even with the new Stamina mode always on. Maybe i should reset to factory defaults and prevent updates.
