Google play connection timed out
JG322779
My WiFi connection is fine, I can use Chrome and Gmail, but when I launch Google play it keeps saying: connection timed out. How can I fix this? Thanks.
2 REPLIES 2
Roadrunny76
Enthusiast
Did you try "force stop"?
Not applicable
Try to clean data in settings: settings - apps - Google Play Store - Clear Data, also you can try to uninatsall update if you have lastest version. If you don't have - try update it Slightly_smiling_Face
