1.Prompt does not charge the battery stops at 90% and then starts to flash on or off completely charged. Charge the original charge
2 The phone began to constantly reboot. He could not take a step on the desktop, so it was up to infinity. but you can turn off was, but when I turned all repeated, battery charging was 40 to 50%
Has this happened after you updated to 5.0?
2 problems occurred before 5.0
at 5.0 going strong overheating and throws the game after 10 minutes on the desktop, and slowly work slows
Have you recently updated? Battery life will improve after some time.
