3G Connection Error
Not applicable
3G Connection Error
Hi, I have just started using a W980i, phone works fine, it is on the O2 network, when I am in a 2g signal area i can connect to the internet, use google maps etc, but, when i am in a 3G HSDPA area, identified by the 'H' symbol on screen the phone will not connect to internet, i keep getting a 'connection error' come up,
I put the same sim card into a Motorola and it worked fine, so it has to be a setting on the Sony phone, (i have also recieved all current software updates, and the connection settings from o2 & sony, direct to the phone)
Can anyone help please?
1 REPLY 1
Dr_Chris
Champion
Perhaps you have to enable GSM AND 3G in Settings---Connectivity--Mobile networks--GSM/3G.
