3G issues.Service Provider Idea
swapnil_gujar
Hello All,
I am facing issue on 3G network provided by Idea. The default mobile network is WCDMA(preffred)/GSM. For these setting the network is very intermittent. I change the network to GSM only, but in that case the internet goes off.And when i revert to WCDMA(preffred)/GSM mopbile network it works but again intermittently. Is this some kind of issue.
1 REPLY 1
Alexander1
Champion
First of all I suggest that you check your APN settings in the phone. Go to settings  > more > mobile network > access point name. Check that the APN settings is correct. I suggest that you try to remove the proxy and port data from the APN settings. Restart the phone and try again.
If you still experience the same behavior I suggest that you talk to your service provider or try with another SIM card.
