some days ago I switched from iPhone to Sony Xperia Z1. I bought some stuff, e.g. the Runtastic Bluetooth Heart Rate Monitor, and it doesn't works with the Z1 (Android 4.2.2). With Android 4.3 this issues should be solved (Smart Bluetooth-Support with 4.3), so my question is, when the Update to 4.3 is available?
Thx and best regards,
Alexander
@AlexanderCWeiss wrote:Hi,
Alexander
hey bud it is avalible on custom rom atm be aware should you do that you may void your warranty, but to be honest according to sony and android they will be relasing 4.4 KIT KAT at the end of this month so on a personal not id wait as they will be skipping 4.3
hope this helped dont forget to give me a kudos
Hi
This was the last post made on Sony's official blog about devices gettings android 4.3
http://blogs.sonymobile.com/2013/07/25/on-android-jelly-bean-4-3/
Xperia Z1 is going to get 4.3 but there is no info about when.
Keep your eyes on the blog for latest official news.
@Nabeel wrote:Hi
Nabeel apprently they are ment to skip this for 4.4 which is releasing this month
As long as there is no official news, there is no skipping. You might be correct but we have no official information as of yet.
Sony Should Directly Update Z1 to Android 4.4 Kitkat, No need for updating to 4.3 then again moving to 4.4
Sony Xperia Z1 rumoured to get Android 4.4 KitKat update in November... is it true? Anyone can actually comfirm this?
Thanks for your information, hopefully we will receive the new updates as soon as possible..... cheers
