After the recent Android os update, the battery usage graph is so small and lost many feature before
MoreYummy
What happended to the old battery usage graph, that shows alot more useful information?
After updated to 6.0 Android, they are all gone.  Now it has the useless graph that is zoom out so far, it is basically useless.
How do we put it back, or it is permanantly gone, taken by google or Sony?
2 REPLIES 2
Uliwooly
@MYSonyAccount
It has been posted before, you can use the search bar to find other posts in the same topic, but yeah the graph it's gone, don't forget to contact Sony directly regarding this >>> Local support
MoreYummy
Ok.  It seems it fixed in the update, there is no setting to change it.    It is a very bad idea. It is pretty much useless now,
I just read other post, I have similar picture on the battery graph.
