After the update icon power saving ://
MrGenc
I have phone Xperia J model...When I first got it I could use the power saving..11.2.A.0.21 but I can not find the icon after installing power saving..WHY?? Face_with_rolling_Eyes
10 REPLIES 10
profile.country.RO.title
_alexdon_
What power saving?A 3rd party app or built in?If you are talking about the transition from ICS to JB,first it was extended standby mode and in JB is it stamina mode.
alexdon
MrGenc
I can not use the current power saving mode..Does a durable power in the new update mode is used??
_alexdon_
What version of android are you on?Settings-about phone and tell here.I really do not get your problem.
alexdon
MrGenc
Screenshot_2014-02-16-13-13-16.pngttt
_alexdon_
You are on JB,so you have stamina mode.You can find it in settings-power management.
alexdon
MrGenc
_alexdon_
Can you change the language to English?I cannot understand and cannot figure out.
alexdon
MrGenc
Thommo
Yes that's the name given to Stamina mode called Extended standby Mode - Tick that box and you will then see an icon in the notification area at the top next to phone signal etc which looks like two hands holding a battery
