Hey guys, I think there is a small problem in the Quick Settings widget after update to 15.4.A.1.9.
When I try to put my phone in Airplane Mode using this widget...
I am taken to this Wireless & Networks screen and here I have to tap 'Airplane Mode' to enable it.
Did anybody notice it? Does anyone have a solution?
In the latest software, when you use the quick setting for airplane mode you will get redirected to this menu. This is not considered as bug but I will forward your feedback internally.
Ok, I am guessing nothing can be done to change this.:smileyconfused:
But it is kind of annoying though, and it worked perfectly when I was on Android 4.1.
Does this happen in Android 4.4 too?
Well, this actually IS a bug, while this is the role of 'Quick Settings' widget.
I could get into that menu without using Quick Settings.
Please correct that annoying bug or rename the widget to 'Slow Settings'
