Alarm clock vibration
Tipu1
I just bought a new xperia m4 aqua and the vibration setting on the alarm clock is so feeble that it does not wake me up. I like to set my alarm to vibrate in the morning so as not to disturb others. Any way the vibrator volume could be increased?
3 REPLIES 3
profile.country.PH.title
MarlonUk1
unfortunately there is no control available for vibration intensity
Tipu1
Do you recommend any alarm clock app with a louder vibration setting?
MarlonUk1
You can try vibration alarm clock on google play
