Android Wear Connected, running sync loop
TCo
I have a new problem(?) with SmartWatch 3: Android Wear in notification center is now saying "Connected, running sync loop", used to be just "Connected". I don't know if it has something to do with this issue or not, but my Z3 has rebooted itself 2 times now in 1 day period and yesterday morning it didn't wake up (didn't wake me up either) and only pressing power + volume buttons shut it down so i could start it up again.
Also today, after random reboot i noticed AVG scanning "Google Play services" and it was after that i noticed this "sync loop". So maybe Google Play services was updated after reboot and it has something to do with this. Everything seems to work fine, notifications, apps, etc, i don't know if this is a problem or some new feature. And i can't tell does this affect battery life yet, i'll see it in the evening.
Resyncing apps, or rebooting SW3 won't make "sync loop" go away.
2 REPLIES 2
TCo
This indeed seems to affect battery life, or something else is. But i found the solution from this thread https://productforums.google.com/forum/#!topic/android-wear/Dm62UKfemIs, in case someone else is wondering...
profile.country.RO.title
_alexdon_
The same for me,I found the explanation here.Developer options enabled:
http://www.androidcentral.com/what-does-connected-running-sync-loop-mean-android-wear
alexdon
