ARM9 Fatal Error
Not applicable
ARM9 Fatal Error
Hi, I just bought my phone 4 days back and now I'm facing a problem Slightly_frowning_Face
There is an error called ARM9 Fatal Error displayed. Below is the full details:
ARM9 Fatal Error
MOD wl1drxmanager.c
00444 Go to dload mode?
If no will break ARM11
Can someone help me with this one? Can't return it back as I have lost the receipt and the same time, the dealer did not fill up the Warranty Form, hence, I cannot use it at all!!!!
I am still hoping this phone will work properly.
thanks a lot in advance Slightly_smiling_Face
8 REPLIES 8
Not applicable
Hi!
Don't panic!
Just remove the battery from your phone, insert it again and turn your phone on again. It will then work as before.
You also need to install the latest software for your phone from from www.sonyericsson.com, then you will hopefully not have this problem again.
Rgds
Not applicable
Hi, I did it several times already, it's the same error.
Also, i tried to install the new software which gives an error as well.. Failed to update (something like that :smileyhappy:)
Is there any other way aside from what u have mentioned? By the way, I have followed the step by step the installation procedure, in case u will ask me Slightly_smiling_Face
Not applicable
Hello!
- When do you get the error "ARM9 Fatal Error"? What is the last thing you do before it appears?
- What is the exact error message when trying to upgrade the software?
Rgds
Not applicable
Hi!
It happened when i was charging my phone, sometimes, checking my facebook, locking the phone, adding contacts.... This ARM9 Fatal Error is always apprearing!
I cant remember the exact message when I have installed the new software, however, I will try it again this evening and will check the message.. but hopefully it will work this time. Slightly_smiling_Face
thanks a lot and please have patience on my questions Slightly_smiling_Face
Not applicable
If this error message does not stop after installing the last update, you should send in the phone and clame a new one.
Not applicable
Hi! yes the message occured almost every 45 mins, I have sent it back and they have give me a new one... but my nightmare did not stop there!!!!!
the new one has a problem as well!!!!!! this is really a crazy phone!!!! This time the error is about gwes.exe!!!! In just 3 hours after I fully charged this phone! gosh!!!!
by the way, when I switched on the phone for the first time, it when to the main screen directly and did not ask for a setting, the time & date have been set on proper time?
Shall I reset it? My worry is, maybe it will be worst if I will reset this crazy phone!
Not applicable
Are you sure you got a new phone? Did you check the IMEI?
Perform a clean reset to bring it back to factory settings.
Not applicable
I give up!
this is a stupid phone I ever had! Just in 1 week this phone makes me realized that the maker of SE X2 doesn't have a brain!
This is not a good phone at all! WORST EVER!!! and because of what I have experience with this, I WILL ALWAYS REMEMBER NOT TO BUY SONY ERICSSON PRODUCTS... STUPID EVER!
In 1 week they replaced it with the same WORST PHONE!! I should have listened that SE is crap!
I lost & waisted my money...and tired of this bloody phone!
DO NOT BUY THIS CRAP PHONE! IT WILL MAKE YOUR LIFE MISERABLE!
