Asphalt 8
gamerr97531
Asphalt 8
I can't find asphalt 8 on play store.
When I search it from my computer and login thorough my Google account it says --incompatible device TATA DOCOMO C5302
What should I do to get the game..
As it seems hardware requirements are enough..
22 REPLIES 22
ArdaNova
You can try to visit the Google Play Store using your desktop PC. From there, you can effectively search if Asphalt8 isavailable for your country. I have tried it personally on my C5303 but I have to ditch it since I need to perform a factory reset on my phone.
gamerr97531
Actually my friends can download it on his Z1..
But I can't download it.. As I already said I tried our on pc too..I stay in India.
ArdaNova
it is compatible with C5303. I can't see why it isn't compatible with the C5302...
try this link. download the APK on the PC, install manually on your device. https://play.google.com/store/apps/details?id=com.gameloft.android.ANMP.GloftA8HM
gamerr97531
Can I play multiplayer if I do that??
ArdaNova
Yes I think.
Uliwooly
@ArdaNova, that doesn't download the APK, what it does is send the app directly to your phone, downloading an apk in most cases its consider copyright infringement.
Sam
Legend
Legend
If you are having problems sourcing a particular third party application for your device I would always advise taking this up with the applications developer.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
Ashroft98
Enthusiast
@Sam There is one question for you.Why does Xperia SP does not support Medium High or Very High graphics for Asphalt 8?Using Low graphics is not really that nice.I know that with Adreno 320 GPU,Xperia SP might play even higher graphics.Is there any way to upgrade Asphalt 8 graphics to Medium or High?
#my driver's name in Asphalt 8 multiplayer is Driver 8501 Grinning_Face
gamerr97531
@Ashroft98 whats your model C5303 or C5302
