unfortunately it will not unless your z was on kitkat it will not as z2 is on kitkat. best option is to back you via google account or use xperia tansfer app to move contents on your z to your z2 .
http://talk.sonymobile.com/t5/Xperia-Transfer/bd-p/xperia_transfer
They are not compatible,backups differ by each firmware update and phone.However,you can rename the .dbk to .zip and try to extract some of the files.
