Just tried to restore my new Z3 Compact with data from my old Z3 Compact and got this error code:
PCCBackupFailed
CompanionBR 1432
What can I do to make it work?
Thanks
Yes it should be the same, but how can I check?
Hi @MCN,
You can try restoring the data to the new phone via the Xperia Transfer feature instead. It allows you to select a backup as the source of the transfer.
