It looks like Sony Z3 compact has a problem playing music via BT on new Philips Fidelio E5.
Making connection not problem at all. Both devices use NFC to connect. Both recognized each other. But when I push Play nex what I hear from the speakers is a terrible hight frequency noize. I have at home at least 5 devices playing musig on Fidelio E5 using BT. None of them have any trouble to do it only Z3. I tryed to connect and disconnect Z3 for many times. The result is still the same ;-(
When Z1 compact is connect to Philips E5, I can barely hear some sound behind A LOT of static.
When will there be an update to fix that?
