I have xperia sp. In it I can hear all incoming and out going calls through bluetooth headst but I can not hear music through bluetooth headset. How can I hear music through bluetooth headset ?
Which bluetooth headset do you have?
I suggest that you go to Settings > Bluetooth > Press on the tool icon next to the headset > Is "Media audio" marked?
If yes, you can always try to unpair the headset and then pair it again to see if the same problem appear. Otherwise I suggest that you try with another Bluetooth headset, perferred a Sony headset.
I thank you verymuch for your reply and response.I am using BH320 bluetooth headset.There is no music audio option but phone audio option is there.However I will try with sony bluetooth headset.
Thanking you.
By
G.Kannan
