try to run it using safe mode
try to perform factory data reset and software repair using Xperia Companion
Thank you for your tip, nolramlb! it works fine in safe mode but when i start it by normal way, the problems back again...i think this version needs several adjustments...and you?!... what do you think about it?
I am having the exact same problem with the Marshmallow update; bluetooth audio is pretty much unlistenable. My friend has an X5 and the bluetooth problems are exactly the same on that phone. This is a hugely buggy update on Sony's part.
Yeah! You're right, huge bug for sony smartphones. My solution (for while) is: turn on led light and cuts desapear even suspended but, bye-bye battery...this last update is a energy eater!!!
The signal strength is now much weaker on all networks than it was before, easily loses...
HI All,
This is a problem that not every bluetooth profiles are included in Sony system 😕 I cannot even find my car handsfree system (Honda Accord from 2006) since I have Android 5.0 from Sony. On 6.0.1 is the same situation.
Months ago I have found on one forum information that Sony just did not implement some bluetooth profile.
It is a crap from SONY because phone should be compatibile with all BT standards. I tried to contact XPeria Care but they suggested to ... change a car
