Bluetooth disconnect
Mrdubstix
hello, I have for some days a problem with my headset, it disconnects all alone and reconnect to Bluetooth, and I just checked with a Bluetooth speaker that's the same thing, would you have an idea of ​​the problem? thank you
Tags (1)
4 REPLIES 4
Uliwooly
@Mrdubstix
test it in >>> safe mode
do you have stamina mode on?
CameronT
Champion
Hi @Mrdubstix,
Welcome to the community.
Can you try restart smart connect?
To do this please go to Settings > Apps > All > Smart Connect > Force Stop > Clear Data, then restart your phone.
Mrdubstix
After several tries, I reboot and also disable smart connect the problem continues, in safe mode the problem disappeared! what is the problem?
Thank you for your help
CameronT
Champion
@Mrdubstix,
If the phone is working correctly in this mode, this indicates there is a third party app causing a conflict with the device.
In this situation I would advise to remove the downloaded apps one by one to identify which app is causing the conflict.
If the phone does not perform correctly in Safemode I would advise to run a software repair on your handset as this is likely to resolve the issues currently being experienced.
