Bluetooth problems
Myller1986
Bluetooth problems
I got Bluetooth lag on my Phone when im playing music, but mostly when its in my leg pocket. If I put it in chest pocket, there isnt any problems whit that anymore.
I got problems when im in conversation to, No matter which pocket i use.
Sometimes i even get a robot voice ๐Ÿ˜•
Tested on SBH70 and SBH20. If I turn of my headset The problem disappear.
Tags (1)
2 REPLIES 2
profile.country.US.title
Qatrium
@Myller1986
I suffered a similar problem with my car head unit, what I've done was performing a software repair using PC Companion and then everything went fine. I didn't try any other solutions, but you can try un-pairing these devices, resetting them, and re-pair them again to see if this will work. If you decide the perform a software repair on your phone, bear in mind that this will erase your internal memory, so take a back up of your important data.
Pond
Hi Myller1986, I have a same issue with you. How do you fixed it? Thank you
