C902 Memory Card problems
Not applicable
My Sony Ericsson is just a fey months old and i have had a persistent problem with my 2GB memory card. The main problem is that it keeps losing my photos and in other folders like Music there are folders with strange names which appear and you cant delete them.
Please help!!!!
4 REPLIES 4
Jeff
Enthusiast
If you can answer these questions we can get started:
1. Are you using a Mac or PC?
2. Have you tried another Memory Card of any size?
3.Have you formatted the card ever, on the PC or the phone?
Thank you!
Not applicable
1. Im using a PC
2. I havent tried any other MC size
3. i've formatted it twice  on the PC it didnt help
KrazyD
Contributor
First backup all your data then Update the phone using Sony Ericsson Update Service. Then format the memory card using the pc and see if that helps.
Not applicable
I met the same troubles, almost each time i open my phone, she will ask me to format my MMC. All ways suggested above have been tried, nothing works!
