Camera issue's
solehin
Camera issue's
, 28.11.2014 I just bought new experia z2.on sunday, I went to a swimming pool. And I tried the underwater photography. Everything seemed to be okay, but something worst happened after I get home. The back and front camera lens got foggy and moisture on it, and my phone still working fine but my indicator turn red. The flaps were on tight and I check it before in the water.help please?
2 REPLIES 2
profile.country.RO.title
_alexdon_
If the indicators turned red,you should contact your local sony team.They will perform a vacuum test and see if it was manufacturing defect or not.
alexdon
dandy63
Leader
Hi, as Alexdon says contact Xperia Care.......strange that its all still working fine tho apart from the misting, under which flap is the indicator red as the reset button for the phone is red :smileysmileywink:
