hi..
i have some trouble with my camera when i use instagram and path.
in instagram, when i want to capture a picture, there's a blank screen on the left side. http://imageshack.us/photo/my-images/42/img20121121171336.jpg/
and look fine after i capture it... http://imageshack.us/photo/my-images/31/img20121121171252.jpg/
so it's more like the left end side, move to the right.
and in path, it's fine if i want to capture.. http://imageshack.us/photo/my-images/594/screenshot2012112117062.png/
but after i capture it, it look like this.. http://imageshack.us/photo/my-images/5/screenshot2012112117064.png/
is there anyone have the same problem with me with these two applications? and how to fix it?
thanks.
ya me too facing the same problem...cant capture photo with instagram
Have you checked on the Playstore for any available updates to these applications?
What are your thoughts about this forum? Let us know by doing this short survey.
nope... there's no updates on the Playstore. and i already re-install the applications couple times, but it still the same with the camera. can you help me?
I've got the same issue, I contacted Instagram but haven't heard from them.
Did you also contact them? If not, please do so that the issue gets noted.
ya add a review in play store..so that our problem can be get solved by instagram team
yes... already add a review in play store for both apps. hope they fix it very soon..
In instagram's settings uncheck the "Use instagram advanced camera".
underneath it says clearly that the feature might not work on every device. 😃
Once unchecked, instagram will use defualt camera app for taking photos.
The instagram advanced camera used to work on the Xperia U, so an update could fix it.
How do one get to Instagram settings?
Never mind, I found how: On profile tab the three dots icon on top right corner.
