Hi Nay900,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
In this situation, I would suggest performing a software repair on the device, as it sounds although you have an issue related to software over hardware. Please use the instructions below.
1. Download the PC Companion software from PC Companion and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
let us know how you get on.
Hi. I have the same problem though not so severe.
Videos longer than about 10 seconds wont allow me to switch off. I press the red button and it keeps recording. The only way to switch off is to press the power key and then i lose the video. And the phone wont switch back on for about 30 minutes.
Thing is I DID the software update about 2 months ago.
I shouldnt have to do it again.
What is the solution if one has DONE a software update?
l
