Good evening people,
I'd like to connect an HDMI camera to the phone and record video. Is this possible? I saw this: http://goo.gl/7BUZCD Apologies if links aren't allowed! But this seems to be to connect the phone to a TV.
Any thoughts would be very welcome
With that MHL adapter you can indeed connect your phone to a TV, but I thought it was out-put from your phone to the monitor/TV not the other way around, I'm not sure that it will work with a camera, but you could take one for the team and test it.
Hi @RachelB,
Your phone supports MHL output, meaning you can (for example) mirror your display on a TV. There is no setting to use the phone as a second display using MHL.
If you wish to connect a separate camera to your phone then the Lens-Style Cameras suggested by @uliwooly are worth checking out.
Also, sharing links is perfectly fine as long as you follow our discussion guidelines
