I have inserted a 32 gb micro card in and its a waste of time as the phone wont even recognise it . I have always used Samsungs and had no problems . How do you move apps ? How do you store photo's on a sd card ? It is not user friendly .
You can set the camera to use the SD card for storage instead of the internal storage if you start the camera, tap the settings icon and select "Data storage".
You can also move existing files like music, pictures and videos to the SD card from Settings -> Storage -> Transfer data to SD card. You can however not move or install apps to the SD card.
