Curious if anyone else is having the same problems I'm having.
I bought a C4 back in March or April I believe. Last month is when everything started going downhill.
As of right now, If I plug the phone into a wall charger while the phone is off, it constantly turns on & off, or cycles, never getting pass the black Sony screen. Eventually after doing it several times. It will begin charging. I'll let it charge to 100% but then thats when I run into more problems.
If i turn the phone on and get to where the OS is running, it may stay on for about 5 seconds before shutting back down. 1 out of 5 times just about. It'll stay on and I can use my phone. Thats when I run into even more problems.
While using the phone & not really putting a load on it. Heck I don't even have hardly any apps installed, just Boom Beach so I can test the phone, it'll warn me the battery is too hot & it shuts down even though it doesnt feel as hot as it would normaly run. If that problem doesnt happen then the battery drops fast. For instance it goes from 100% down to the 60's, on average, then shuts off. After that I'm back to the first problem and it's telling me I have 0%-15% charge.
I sent the phone off to Sony cause it's under warranty and after two weeks I got it back. They did a software upgrade as the fix. Took it out the box, plugged it to charge as was recommended, and boom. Same exact problems.
I'm really leaning towards a bad battery but I took my phone somewhere else for a second opinion & they dont believe its a bad battery. They think it could be software or something else major.
Has anyone ever come across this issue? It really frustrates me. I just want my phone working good cause I really do enjoy having it. I dont really wanna go back & forth with Sony trying to get it resolved while being stuck with a piece of crap ZTE phone for back up during the time.
Hi, I have the same issues. I bought mine about 9 months ago and it starts to turn on & off since 4 months ago, and till now i didnt find any solution of these issues. I've tried to repair the software (on PC) a few times but it still do the same. This phone is really great, but with the charging and battery issues its really haha. So if you have found the solution, reply this post :D. Thanks
