connection.issue with smartwatch2
holmatro
Hi all,
I'm wondering if anyone can shine a bit of light on my problem
I have an xperia sp and when I connect my smart watch 2 to it through blue tooth, it disconnects from the Internet? It will only reconnect when I disconnect the watch. I'm going its something simple.
Tags (1)
8 REPLIES 8
le_Bob
I have the same problem, when I connect to a bluetooth receiver or something else I have no Internet connection. Haven't found any solution yet
GreekXperiaSp
Contributor
Yes this is a known bug that exists in the current update of the phone...When you open bluetooth the data traffic disconnects and closes and getd back in use when you disable bluetooth...Lets hope that the new update thats coming will fix this bug and all the others that Sp users are facing..
LordzWiLL
Hello,
I have the same problem. I can't connect to my wifi network when smart watch 2 is connected to the phone. Pease SONY do something !!!
Cawts
Same issue here, it is not just the smartwatch, I have a Garmin Fenix2, it will not connect via bluetooth until I turn the WiFi off.
charlest
Hi all,
I've a similar issue with my SP running Android 4.1.2  Not sure there's any workaround.
In my case, the bluetooth device is a Sony Dualshock 3 Controller.
rolandoprosales
Reading all the posts I have the same problem with Bluetooth and Wifi, I thought only my xperia xp has the problem, but It seems to be a mayor problem for Sony.
mrl
Same problem here.
Elmo5
Me too.
Ricard from Sony promised last spring to escalate this but insted Sony stopped supporting SP. No cure to be expected?
