copying numbers in call log
bol3iz
Hello, is there a way to copy unsaved numbers in the call log to clipboard?
It is getting really annoying that you have to add a new contact in order to copy the number
Also, is it possible to copy the IME number to clipboard (by typing *#06# in call log) ?
2 REPLIES 2
Uliwooly
There isn't a way to do so, you might need a different phone app
Uliwooly
Just realized a way around it
Long press the number on the call logs > Edit number before call > you will see the number twice, long press the phone number at the bottom > copy
